Realistic view surfaces are transparent
In the 3D view, in realistic mode, some surfaces are transparent. I use the "opening in a wall" tool but the color does not apply to the interior faces of the wall. I tried cutting the wall another way but the problem is still the same.
How to solve this problem ?
see attached capture
Use the Paint tool to paint a material on the edge.
....using the Wall Join Tool to Miter corners or change Butt order might work as well.
