Hi!
I just downloaded Revit 2017 onto my new laptop, which is a massive upgrade from what I was previously working on. Unfortunately, the realistic view in my revit looks awful (please see pictures attached). I have tried a couple of things to change it and I can't find a solution to the problem. If anyone has seen or experienced this problem, please send me he solution.
This is the realistic view - notice how the materials are showing up
This is my rendered view - this is what my materials actually look like.
Go into the Material Editor and edit the material. Check Use Render Appearance.
I think that is where your problem lies. If I am wrong, then please feel free to share a stripped down file.
@Anonymous - take a look at these -
All else failing - can you share a file that shows the behavior?
Hi!
Thank you so much for such a quick response! I'm amazed! I tried your suggested solution and it asn't worked for this problem.
God bless you!
Hi!
The same files behave perfectly on my other computer when I try it on there, so it's not the files that are wacky.
Warm Regards,
Cherise
@Anonymous did you follow the links that I had sent you? This definitely has something to do with the computer then.
Open R>>Options on both machines, make sure that both match the picture below.
Hi!
I'm having a look at the links you have sent me and I will give you feedback as soon as I can.
Again, thank you so much for all of your help! I will see if it maybe is the computer and see what I can do.
God bless you!
That means that you are using Hardware Acceleration.
In the Material Editor, try playing with this -
(grasping at straws here)
All else failing - can you share the file?
