realistic view only shows gray color
trixieeunice.gapol
Community Visitor
Community Visitor
trixieeunice.gapol
Community Visitor
Community Visitor
basically when I open a file, it's preview shows the real color, but it's all gray when it's opened. How to overcome? Thank you.
rxi.gg
Try "Consistent Colors". It works? If yes, you must edit your materials.
If this doesn't work try changing phase filter to "Show Complete"
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
L.Maas
It might be your phase settings.
For example if you modeled the building in Existing phase and then you have your 3D view in "New Construction" and your phase filter on "Show All" it can give a result like this (using default templates).
Louis
Please mention Revit version, especially when uploading Revit files.
Set the view's phase filter to Show Complete.
Set the View Phase Filter to "Show Complete"
