Real Batch Printing
5 ANTWORTEN 5
Nachricht 1 von 6
Lucas_Giovanola
672 Aufrufe, 5 Antworten
Real Batch Printing
Hi everybody.
I´m looking for somthing that allow me to print several sheet of several models.
Like a real batch prosses where you choose the sheets of the files you want to print.
Now working on a big project with more than 20 rtv files each of them with sheets to print.
So Imagine when you have to print .... a nightmare really.
Any app? Idea ? wil be higly appreciated.
Thanks.
5 ANTWORTEN 5
Nachricht 2 von 6
L.Maas
als Antwort auf: Lucas_Giovanola
Have a look at RTV tools. I think this might do what you need.
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 6
Lucas_Giovanola
als Antwort auf: L.Maas
Thanks @L.Maas
Near. The rtv tools Batch process works over open models.
So I have to open model by model and then run the batch process.
I want something like "publish option" we have in autocad.
Nachricht 4 von 6
L.Maas
You could contact the creators of RTV tools and see if they can implement this function.
Other solution might be to use Dynamo (in combination with RTV tools?).
Dynamo has functionality to batch open project files.
Louis
Nachricht 5 von 6
I like to use Xrev Transmit...since I create a lot of PDF files it will automatically name each sheet based on what  I want it to be...so if I want sheet number only that is what I can apply.
You can print to a plotter, save to pdf and export to dwg all from one click....but I usually did the dwg's separate as PDF and plotting was more important.
Nachricht 6 von 6
Lucas_Giovanola
Good point.
I think I will try to combine. batch open projects files with Print pdf with dynamo
Firstable I have to learn dynamo LoL.
