Re: What exactly is a "Building Pad"?
8 ANTWORTEN 8
Nachricht 1 von 9
mairh_tsek
7019 Aufrufe, 8 Antworten
Now my building pad and the floor in my lower level are in the same elevation.
Normally were we create the building pad?
 In my case I have the floor , the slab , and the insulation [ see the attchment].
Thank you in advance!
8 ANTWORTEN 8
Nachricht 2 von 9
georgehobel
als Antwort auf: mairh_tsek
a building pad is a lot like a mouse pad... not much good if it get wet.
George Hobel
Reflections of Charlotte
Residential Building and Design
Nachricht 3 von 9
A building pad is a tool to create a build-able, more often than not, a flat area for the building or other structure to sit on.  I consider it more of a site preparation component rather than a building component so I normally don;t use it as the building slab.   But there is nothing saying it cannot be used as one.  If your building has mat slabs you can use building pads for them.
Nachricht 4 von 9
georgehobel
als Antwort auf: ToanDN
exactly Toan... the building pad is always something that is prepared during sitework, before any construction begins.  You wouldnt even send in a surveyor to stake a footing before your grader came in to prep the site (create the building pad). I would imagine that if you started to call your slabs your building pad, you would encounter come confusion in the field.
George Hobel
Nachricht 5 von 9
cbcarch
In Revit ( and perhaps the actual job site ), the Building Pad would represent the "sub-grade" or compacted fill under your concrete slab.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 6 von 9
MostafaElashmawy
Bottom of building pad to be equal to excavation level.
so usually I use it instead of blinding concrete.
Mostafa Elashmawy
Nachricht 7 von 9
Corsten.Au
Consider modelling in revit as the process you will follow in actual construction.
1. Create a building pad for the entire building envelope, excavation they will do as per actual
2. then create foundation,floors, footings modelled as per actual construction.
3. the soil you excavation, now you will need another topography / soil to fill the gaps.
you may model the new topography to fill the soil, new elvations etc or just you may use fill region in section
to show the earth...
( hardcore revit users would model each and every element as per construction o that it shows correctly in
sections, elevations, 3d view.. and thats the whole point of BIM / Revit modelling..
Cheers!
Corsten
Building Designer
Nachricht 8 von 9
mairh_tsek
als Antwort auf: Corsten.Au
If I remove the building pad down from the building and make it only around from the building, the toposurface exceed the lower floor of my building.
But if I make the building pad also down from the building I will have 'two' floors.
Any suggestion?
See the attachment
Thank you im advance!
Nachricht 9 von 9
vabuk2013
But if building pad is compacted earth, why should not it would be for whole site. Again if it is made of concrete what would be its relation with footing, columns, floors? What would be the structural details and its effect on load calculation?
