Re: Walls not connected but can't change height
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
lysaghtassoc
521 Aufrufe, 2 Antworten
Morena everyone,
I have a problem here where I've noticed that an external wall and an internal wall which are connected to a gable wall.. are not supposed to be like that. I've had a bit of a play around where I've tried changing the height, connected it to the right level, disconnected all together, and detached from the top base. I'm lost!
There shouldn't even be that weird little gable wall piece in the middle.. So if you could possibly help me with that too, I'd be very grateful!
Kind regards,
Jane
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: lysaghtassoc
Select Wall, press Detach Top/Base and then press Detach All on the Options Bar.
...if Detach All is grayed out, then I suspect the Wall Profile is edited.  Maybe that's what's going on.   Reset Profile.
Nachricht 3 von 3
lysaghtassoc
als Antwort auf: barthbradley
Thank you very much, it must have been connected to something I couldn't figure out!
