Re-using assembly sheets between projects. Why does this not exist?
1 ANTWORT 1
Nachricht 1 von 2
hammadhk
133 Aufrufe, 1 Antwort
Let's say we have a standardized element, an assembly wall containing framing and cladding. We use it in multiple projects as an assembly of structural framing and walls, and make an assembly sheet out of it. This is a common practice in industry.
Why. Do. I. Have. To. Make. The. Assembly. Sheet. Again. Every. Time.
I can copy the assembly but i have to put in each dimension, again. In the end it must look the same as in the other model. Am I missing something? I do not want to use/share a 2D detail because the wall elements might undergo changes, such as holes for MEP, etc.
1 ANTWORT 1
Nachricht 2 von 2
L.Maas
als Antwort auf: hammadhk
Make it part of your project template?
Louis
Please mention Revit version, especially when uploading Revit files.
