Hi, I have created a part in Fusion 360, applied a material finish all ok. I'm now looking to export and place into Revit LT...I exported as a successful OBJ file format, placed into Revit after making a Family from said export but I can't get the material to show (just a standard white plastic Autodesk one, created in Fusion 360). Any ideas? I have looked at Object Styles, but still can't get it to change and show white plastic...is there something in Visibility Graphics settings maybe? Thanks in advance.
Gelöst! Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Go to material and check and see which OBJ material it is set to. Normally it would have weird default name. When importing OBJ into Revit family, often the material will add tint to it. I would turn the tint off and you should get the proper material color.
Also if you want the OBJ material shows up with proper shaded material, I would check on the use render appearance.
