Good morning, everyone!
I've encountered a problem as I went to change the size of the stud in my external walls. Going from 90mm studs to 140mm studs has for some reason created this problem where the inner structure of the wall will connect to the roof, but not the outter cladding. I have attempted to attach and detach, to re-draw the wall with the new stud shape instead of just modifying, and even closing revit just to check!
If anyone has any ideas, please let me know
Kind regards,
Jane
Gelöst! Gehe zur Lösung
Gelöst von Lachlan-JWP. Gehe zur Lösung
The foot print of your roof is still in the same place as it was before you changed the wall thickness. Edit the roof footprint and use the pick walls option to relate the roof footprint to the outer edge of the wall.
