Re: Can't see 3D View of Revit Model
2 ANTWORTEN 2
Nachricht 1 von 3
966 Aufrufe, 2 Antworten
I am a new Revit user. In revit on pressing shift, the 3D model goes away. The model cannot be zoomed in and it can rotated only from a certain distance. Also in the options other than wireframe, the wireframe lines appear. What do I do? Please help.
2 ANTWORTEN 2
Nachricht 2 von 3
Sahay_R
als Antwort auf: Anonymous
Some questions for you -
1) Do you have rooms in your model? Try turning them off
2) Do you have any .dwgs loaded in to your model. Try to unload them
If these measures do not work, then can you share your file?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 3
als Antwort auf: Sahay_R
Go to Graphics Tab under Options and check Video card status. Sounds similar to an issue I get sometimes when my driver version mysteriously gets rolled back.
