Announcements
RE: Artificial pendant lighting not illuminating
crjmail1_0
crjmail1_0
***Hi I know I tried earlier...maybe got lost...?? Any guidance would be greatly appreciated...thanks in advance***
Hi, I'm hoping you may be able to advise.
I can get the Lighting Fixtures Ceiling Linear surface mounted 600x1200mm (from supplied Revit family in Revit LT) to show illuminance,  but not the pendants (again from supplied Revit family in Revit LT -Lighting_Fixtures_Pendant_3).
I wouldn't design both types of pendant, but include both as both have a problem with. Is there an easy fix to this? I believe both pendant types have a light source and are ticked to show. I also rendered at night too. Thanks, Regards J.
(Please see attached screenshot).
azad.Nanva
if i understand , you can use same material or sahre your family or project here.
rjght ?
