Re: Acquiring Coordinates from a point cloud in Revit 2019?
1 ANTWORT 1
Nachricht 1 von 2
quoc.bad
572 Aufrufe, 1 Antwort
Hey Autodesk team,
I just want to raise the issue with acquiring coordinates from RCP files.
when I am using Recap I export an RCP file.
I then link that into Revit 2019.
Go to Manage , Coordinates, and Acquire Coordinates. and I can't select the file?
I recall thise use to be possible?
Kind regards,
QP
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: quoc.bad
If you want to set up Shared Positioning between PC and Project. put the PC in it's own RVT and then Link that PC RVT into your Project.
