RCP
RCP
Message 1 of 16
RCP
Hi All, have an issue with a reflected ceiling plan i have spent so much time trying to solve hope you can help. My RCP has a compound ceiling, it is hidden from view and i cannot unhide as the unhide option is grayed out. Underlay is set to RCP, ceilings are turned on and transperancy set to zero.
Any help will be appreciated
Replies (15)
Message 2 of 16
Cut a section and check the height of the compound ceiling, then check if you view range look far enough to see it.  Also, why do you need the Underlay that set to RCP?  What are you trying to see from it?  Normaly the underlay of a RCP is to show floor plan items, so it is set to Plan (looking down).
Message 3 of 16
Hi Toan, it is my ground floor ceiling plan, ceiling height is 3500, top prim range set to Level Above ceiling (ground floor ceiling) with top offset of 3700.
View depth unlimited,  underlay changed to ground floor and is set to looking down still cannot unhide. Assume it something in visability or view range but cannot figure it out, thanks
Message 4 of 16
ennujozlagam
@Anonymous hello, is your ceiling type is plain or with grid? can share part file so we can check. thanks
Message 5 of 16
It is a grid, file too large to attach, i can send you google link?
Message 6 of 16
ennujozlagam
@Anonymous hello, yes sure i pm you my email add and Revit version. thanks
Message 7 of 16
Sure i run 2017 what is your email address
Message 8 of 16
ennujozlagam
@Anonymoushello, i pm you already, check your mail. thanks
Message 9 of 16
Its ok i got it send you google invite now
Message 10 of 16
ennujozlagam
@Anonymous Hello, is your file is a workshared file? Are you working alone on the project or with other user's. If you are working alone > open the file > tick detach from central > discard worksets > and save. Try again the unhide element and see if helps. Thanks
Message 11 of 16
I have uploaded just now the file as separate folder to share with you, i am working alone you will have it in 1 minute
Message 12 of 16
ennujozlagam
@Anonymous hello mate, please see attached is this you wanted it to be ceiling lines? thanks
Message 13 of 16
Yes Junne, thats it, but what did you change to make these ceiling materials appear? Many thanks
Message 14 of 16
ennujozlagam
@Anonymous hello, just a standard procedure in revit > click the bulb > select the boundary of your ceiling line > unhide element. thanks
Message 15 of 16
Thank you so much, Junne, was not aware that can only select ceilings on boundary, so simple if you know how!!, appreciate it
Message 16 of 16
ennujozlagam
@Anonymous hello mate, no worries, glad to help. thanks
