Hi, I have my existing walls showing as solid on my Partition Plan. I would like the existing walls to show solid on the RCP. What view template settings do I need to change? (thank you in advance)
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Set the view's phase to New Construction and phase filter to Show Previous + New.
And View Templates are created by you so other people cannot tell you which one to use unless we have the model to look at.
