RCP doesn‘t show in print
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
MF-AC
768 Aufrufe, 3 Antworten
Hi everone,
I‘m working with Revit 2019. In my project I created ceiling plans to show the structural Elements nessecary for the floor plan. On a sheet I stacked the views to get the correct presentation. This way worked just fine, but somehow Revit has decided it‘s not going to do it anymore - now when I print a pdf the RCP is not printed.
Any suggestions what might be the Problem?
Tags (3)
3 ANTWORTEN 3
Nachricht 2 von 4
ennujozlagam
als Antwort auf: MF-AC
have try to install latest updates from autodesk and see if helps. or post some screenshot bor better understanding. thanks
Nachricht 3 von 4
MF-AC
als Antwort auf: ennujozlagam
After trying a lot of workarounds we found a solution. We swichted display mode from hidden line to wireframe and now its working again
Nachricht 4 von 4
bin
Maybe you should try Underlay.
