RC stair connection with foundation slab
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
1328 Aufrufe, 8 Antworten
is there a way to obtain a connection like this (red shape) using "stair" generator?
If not, what would be the easiest way to make such a connection!?
Regards!
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: Anonymous
In-Place Component would be easiest IMO
Nachricht 3 von 9
Model it in place and use Linework to remove the lines in section/elevation/3d.
Nachricht 4 von 9
als Antwort auf: ToanDN
Thanks!
...would I be able to join stairs with in place element?
@ToanDN
How do you mean "use linework to remove the lines"?
Regards!
Nachricht 5 von 9
See attached for what i meant.
Nachricht 6 von 9
@ToanDN
Thank you!
I'm experiencing problems with model in place (generic model).
Revit is asking to pick "work plane". How can I pick Section view as a work plane!?
...tried to make a workaround by drawing exact shape in horizontal plane (foundation slab) but then Revit doesn't allow me to rotate extrusion....!
Regards!
Nachricht 7 von 9
Oh, I'm sorry. I just thought you knew what an in-place component was and how to do one.
When to go into In-Place Component you need to select a Workplane to draw on.  The Workplane you would select would be the external (outer-face) face of the stair run (in 3D View). It's that face you would sketch your custom profile on.  Naturally, you will be sketching the profile for a solid extrusion.  You can resize it's depth once created. Just concentrate on drawing the sketch boundary and closing out of sketch mode.
Nachricht 8 von 9
als Antwort auf: barthbradley
@barthbradley
@ToanDN
Thank you!
I was trying o select work plain in 2D....my mistake....
Nachricht 9 von 9
georgehobel
@ToanDN   I havent used that tool yet, but its been on my list of things to find out...thanks...
George Hobel
Reflections of Charlotte
Residential Building and Design
