RC spread footing cut
5 ANTWORTEN 5
Nachricht 1 von 6
348 Aufrufe, 5 Antworten
is there a way to cut red triangle and rectangle:
Regards!
5 ANTWORTEN 5
Nachricht 2 von 6
dzanta
als Antwort auf: Anonymous
check the wall joins...they may be off...
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Nachricht 3 von 6
cbcarch
The footings automatically join and respond to the walls--so, try editing the wall joins and see if the footings clean up.
For instance, try using disallow join on one or more of the walls, and then drag the ends manually, and see if the footings join differently.
You can also drag the ends (blue dot) of the footings.
Worst case, you could try using an in-place Void family to cut the footings.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 4 von 6
Ilic.Andrej
you can just stretch the footing and then use align tool. Align footing edges to fix these joins. @ToanDN tought me that :leicht_lächelndes_Gesicht:
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 5 von 6
disallow the the wall join of the wall that's intersecting the angled transition (the one that's vertical in the top picture).
Nachricht 6 von 6
als Antwort auf: barthbradley
Thank you!
I managed to fix one by moving the footings blue dot, and the second one by editing wall joins.
