Hello, I have two questions regarding Revit 24`
1. How to make that reinforced concrete beam cut out a wall element, now both elements are overlaped. In the beam element family is marked "cut with void then loaded" box.
2. How to set properties or what, that the length of the beams not be adjusted at the intersection of the walls? Now, where are the walls joints "L" or "T" shape, the beam is visually shortened, although the properties shows a good length.
Thank you
use the join tool.
Please note, if the wall structural usage is "bearing", most likely you'll need to use the switch join order since the wall takes higher priority over the beam (Autodesk is still not willing to fix this bug).
If the wall structural usage is "shear" or "structural combined", the beam will not be automatically joined with the wall and you can just use the join tool.
Hi, after i used joint tool ( i, mot sure it is related), concrete beam and wall has same cover for reinforcemenet. How can be solved what cover was just for concrete beam.
Thank you
