Vector Processing: this method uses formulas to make lines and curves so that when u zoom in on a PDF file it remains smooth. Also, this method produces smaller PDF files and is faster than Raster Processing.
Raster Processing: this method will use individually drawn pixels, which makes a lower quality output compared to Vector Processing. Furthermore, Revit will automatically choose Raster Processing if the views contain one of the conditions written below:
- The view contains an image or decal
- The view contains a point cloud
- The view use Shading or Realistic style
- The view use shadows, gradients, sketchy lines, or depth cueing
https://lazybim.com/export-pdf-from-revit/
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
