I have problem when printing images which require raster processing, eg. facades with shadows on, 3d views with consistent colors mode on etc. All prints have white lines visible - I suppose they are the division lines from raster processing. I have the same problem in Revit 16 and 17 and also on different computers. Did anyone figure out how to deal with it? It's very annoying. In the picture you can see the example of this.
Regards
Maria
Solved by ToanDN. Go to Solution.
Yes, I print it to PDFs. Currently I use PDFCreator, but the same problem was with another PDFprinter.
Image resolution is set to 600 dpi, and this is the only parameter from your list that I can change in settings.
I do not have PDF Creator at the moment but I can check when I get home. Below are the options from Adobe Acrobat Standard settings. They are OOTB settings just to show you what can be adjusted.
