Raster and Vector Views in same Sheet
16 ANTWORTEN 16
Nachricht 1 von 17
3202 Aufrufe, 16 Antworten
In the Revit 2017 help link:"About Vector Processing and Raster Processing",there is the following sentence:
"If a sheet contains multiple views, Revit uses raster processing only for the views that require it. For other views on the sheet, Revit uses vector processing."
I wish it was true, because, every time I have one of the views with any shading/shadows, all of the sheet (with exception of anotations, dimentions, etc), becomes rasterized and blured. Even autocad x-refs.
Is it a bug? Anywone is having the same behaveor?
Tags (2)
16 ANTWORTEN 16
Nachricht 2 von 17
riccardo.evangelista7JHLC
als Antwort auf: Anonymous
Hello Susana
My name is Riccardo. I am a Revit specialist.
In order to have a closer look of the issue I would appreciate if you could send a screencast.
If I do not hear from you within 4 business days, I will archive the case. Despite of it, if you have any additional questions or concerns you can still post them here.
Best regards,
Riccardo Evangelista
Autodesk Support Team
Autodesk Revit Technical Support
Nachricht 3 von 17
@riccardo.evangelista7JHLC
Really???  Are you a person or a bot pulling an automated response?
The issue is described very clearly with a quoted Revit message.  What further information do you think a screencast will prove?
Nachricht 4 von 17
Hi Susana,
HERE you will find useful information regarding Vector Processing and Raster Processing.
Please let me know if this helps you to resolve the issue.
Best regards,
Nachricht 5 von 17
als Antwort auf: riccardo.evangelista7JHLC
Thanks, ToanDN! That's exactly what I was thinking.
I'm planing to use a generic autodesk project to replicate the issue and send you, Riccardo, the rvt file and dwf outputs for your analisys, but haven't got the time yet.
Now about your last response: Very funny the fact that your link is from 2015 help file! (I though revit had compulsory upgrades by now... Why would you send me this link? What lead you to think we don't work with the most recent version?)
From 2016 onwards it's states exactly what I said and it's prety clear to me what it means, especially because autodesk chaged the text from the 2015 version that you send, so it clearly means that something improved sinse 2015, or at least it was intended to change...
Please let me know if the files I'm planing of doing are of any use to you.
Thanks anyway!
Nachricht 6 von 17
Hello again Riccardo.
Hope I'm still within the 4 work days...
So I finally got an hour to do the test file.
Attached I send 3 dwfs exports of 3 diferent views: one just with lines prints as vector; one with solid colors prints as raster; and one with solid color for the sky that prints as raster as well.
I did this 3 because somewhere I read that autodesk had made changes to make pdf/dwf prints to come as vector when solid colors (not graded shades) were present. Guess it didn't work...
I will continue the post in a second one because can't attached more than 3 files...
Nachricht 7 von 17
Cont. ...
So the plan now was to export a sheet with those 3 views and see the result. I would expect each view to keep the same aspect as before, the view with lines as vector ans the other two as raster, but no, all 3 view export as raster...
Is it normal? A sheet can combine vector and raster feactures (anotation elements allways export as vector) so there is no reason why we couldn't have vector and raster views in the same sheet.
I will send the original revit file I used so you can make your own testing if you like.
I will waiting for you feed back soon!
Best regards and have a nice weekend.
PS: if you can't see the diference between the 2 exports, just look at the tree lines of the black and white view in the alone and together files.
It gets pixelized and blured instead of a clean curved line...
Nachricht 8 von 17
martinTstewart_Adsk
Hi Susana,
This is Martin with Autodesk Technical Support.  I promise I am not a bot, but I cannot speak for Riccardo.  (BTW, my favorite robot of all time is R. Daneel Olivaw and it IS suspicious that the first names may be the same).
What you are describing is actually a known issue being looked at by our development team. So to answer your original question, YES, this is an issue that needs to be addressed. Here is a public article that can be monitored for a status change on this issue: Sheets: All views are printed with raster processing when some views should get vector processing
When there is a fix (or progress or resolution of some sort), the “Status” comment in that article will get updated.  The only workaround at this time unfortunately would be to not mix those views on the same sheet.
I’m sorry for this hassle (and the earlier bot / 4 day countdown confusion). I hope this helps. I'm stepping out now to audition for Westworld.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Martin Stewart
AEC Support Specialist
Nachricht 9 von 17
als Antwort auf: martinTstewart_Adsk
Thanks, Martin, for the reply.
I tried to rechearch the web for this problem before posting anything here (this was the first time I ever did that), but couldn't find anything. Rechearch could be improved and the forum subgroups too, because I go confuse the first time.
(For the rechearch improvement, I think the link for that issue you send could be in the help page I send - pertinent information at the right place, I would say).
Anyway, just wanted to check one information I receaved.
Is this issued corrected in a new "update" about a week ago, or is still open? And about the solid color test I did. Is it suposed to export as vector, or that is still something impossible? (There was only one I forgot to test: making the backgound as an image insted of revit solid color... Could that do the trick?)
I will wait for your reply.
Thanks again, Martin.
Nachricht 10 von 17
martinTstewart_Adsk
Hi Susana,
The update for this has not been issued yet. As far as your other workflow idea, I don't think that will correct it, but you might want to give it a test to see how it works for you.
Autodesk posts/publishes thousands of articles and searching them can be hit or miss at times.  I use Google extensively myself for searching for Autodesk articles and related blogs, websites, and whitepapers. When I do find a key article, I may bookmark it so I can find it again. And I even keep a running list of key articles using copy/paste.  But with that said, I know Autodesk is continually working at improving findability of articles/information along with improving the search function.
Martin Stewart
Nachricht 11 von 17
Can Autodesk please issue a service pack for 2017 that fixes this? It is a very annoying issue and my office isn't willing to upgrade to 2018.
Nachricht 12 von 17
No need. We're up to R2019 and the issue still hasn't been fixed. Lachender Smiley
They've got your subs though - so, you know, it's not like they care that there are 3-year-old (and older!) bugs everywhere.
Nachricht 13 von 17
I just did a test (2019) and only the view with shadow is printed as raster, the other view is still vector and crispy.
Nachricht 14 von 17
bwill828
I notified the mods that this is INAPPROPIATE calling this SOLVED!
Googling this problem and seeing SOLVED and wasting time reading the entire thread for the so called SOLVED solution and there is none is totally INAPPROPRIATE!!
Please remove SOLVED from this thread!!!
To be clear, this is not pointing the finger at Susan!
Nachricht 15 von 17
Yien_Chao
it is a well known issue, and they have better priorities (like adding slanted walls...)
for the moment, when we really have to do it, weprint the sheet without the raster image, then print again with the raster images.. and then do the job of copy paste, in bluebeam or even Adobe InDesign.
Nachricht 16 von 17
als Antwort auf: Yien_Chao
Do not set print to Raster under print settings then yoi can print mix of raster and vector views and sheets in the same print. I have never had any problem doing that.
Nachricht 17 von 17
Yien_Chao
als Antwort auf: ToanDN
well not exactly for every case : for instance, try to print a mix of views and let only one of them in 3d with shadows...
