Randomize Color Schemes (HVAC Zones)
3 ANTWORTEN 3
Nachricht 1 von 4
rmartinez-vazquez
247 Aufrufe, 3 Antworten
Does anyone know a way to randomize colors for the color schemes? Like maybe an app/tool? I have noticed this several times in my projects that after a certain number of zones modeled, Revit will default to a purple color
3 ANTWORTEN 3
Nachricht 2 von 4
HVAC-Novice
als Antwort auf: rmartinez-vazquez
what version and all updates applied?
After how many zones does it change assigning different colors? i never saw that, but also don't have os many zones.
Does that happen with other color schemes as well?
Revit version: R2025.4
Nachricht 3 von 4
rmartinez-vazquez
als Antwort auf: HVAC-Novice
After about 100+ plus zones. And this was a common theme in Revit 2021,2022,2023. I did not use zones prior to Revit 2021 but I bet it would be common also.
Nachricht 4 von 4
HVAC-Novice
So what are you on now and are all updates applied?
They changed to the softer colors a few versions ago. Maybe that is when it went off the rails.
Do you have the same issue with other color-legend items (spaces etc.)?
I stopped using Revit HVAC zones (I use the Ripple HVAC tool, and that rightfully uses space parameters for zones). if HVAC-zones is the only issue, you may consider doing the same (and try the tool, it is free and great)
https://rippleengineeringsoftware.com/demystifying-hvac-zoning/
