Random boxes before or after text?
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
HUNTERKARAM8
520 Aufrufe, 11 Antworten
When I pdf my files in Revit some boxes show up before or after text and not sure why. This doesn't happen with all numbers. They do not show in Revit but only after print/pdf. Anyone know what it is?
11 ANTWORTEN 11
Nachricht 2 von 12
a_meteni
als Antwort auf: HUNTERKARAM8
What PDF driver you're using? Font name?
Nachricht 3 von 12
HUNTERKARAM8
Arial text and the 2023 pdf option next to the printer at the top
Nachricht 4 von 12
HUNTERKARAM8
als Antwort auf: a_meteni
Nachricht 5 von 12
See if toggling this checkbox helps.
Nachricht 6 von 12
HUNTERKARAM8
als Antwort auf: barthbradley
That did not work
Nachricht 7 von 12
HUNTERKARAM8
it seems to mostly deal with page/sheet numbers
Nachricht 8 von 12
HUNTERKARAM8
top image is in Revit while the other is after it is a pdf
Nachricht 9 von 12
Did you add Unicode character to sheet number (manually or via an add-in like pyRevit) ?
Nachricht 10 von 12
HUNTERKARAM8
als Antwort auf: ToanDN
it is possible that it was in the existing file, is there a way to remove it to see if that would work?
Nachricht 11 von 12
Sure, just open the sheet index schedule, select each affected sheet number cell, highlight the entire number, delete and re-enter the value.
Nachricht 12 von 12
HUNTERKARAM8
that worked, thank you
