Ramp Problem unexpected
1 ANTWORT 1
Nachricht 1 von 2
mzmaso90
111 Aufrufe, 1 Antwort
Hello Guys, Do you think that this warning message should come from a wrong  procedure in doing this ramp, maybe from border between two different floor or is a bug?
It said that has happend a unforeseen error. The operation has been cancelled to prevent that the project would be damaged. Can you help me?
Each contour line has been verified to  understand if they are overlapped ore not.
Thank you for your time and disposability.
Best regards Lorenzo
1 ANTWORT 1
Nachricht 2 von 2
Lachlan-JWP
als Antwort auf: mzmaso90
Your ramp needs a run line. I would start by sketching out the ramp with detail lines, then trace over your lines with the ramp tool. That should give you the ramp that you want.
