Why I cannot put a slop annotation in ramp? Or why ramp tool does not works like stairs (overhead lines/annotation lines/a temporary dimension while creating a ramp landing)?
This is true. The ramp tool doesn't have all the features we want. You can add a slope to a ramp in 3d. If you want to use the slope desigenation in plan and sections you can always use the ramp tool as a layout and replace the ramp with a floor. Floors will host a slope tag correctly.
I am learning Revit on Revit 2019 and I noticed there are no temporary dimensions when creating landings on a ramp. I use model lines to work around this but it's a bit of a long-winded process and a bit frustrating, especially since this feature works so well for stairs. Are there any plans to make this work in Revit 2020?
