Hi Guys, im trying to make a curtain panel for gable walls, the custom curtain panel works fine in straightforward situations but it wont cut the panel on the gable, show an error "custom panel cannot be created" and changes it to a glazed panel,
any help is greatly appreciated
If your CW uses System Family Panels, use can use Attach Top/Base Tool to attach the Gable Wall to the Roof -- or Edit the Wall Profile manually.
....wait a minute. Maybe I misread the question/screenshot. Post the file. You can attach it to a reply post.
I think system curtain panel will work fine. by edited the profile. if not try to share sample file
Curtainwall panel don't like any sloped or curve profile. It will force to replace with system panel. Your alternative is to use mullion as corrugated panel. See attached.
