Railings
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
2225 Aufrufe, 4 Antworten
Railings
Is it somehow possible to create a door in a railing like this https://goo.gl/images/iJ3zjQ
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Place it as another railing type in the space.
Nachricht 3 von 5
- Separate the railing sketches to create the opening for the door
- Create another railing that resembles the door
- If you need plan and elevation swing graphics then you can use detail lines/components
- If you have lots of them to be placed, you can create a non-host door family and use it
Nachricht 4 von 5
...something like this:
Nachricht 5 von 5
Corsten.Au
Hi
this is just my experience modelling that situation...
but please go ahead if you find it easy modelling in Railing..
on Plan, Its hard to show a Gate, its swing if you are using a Railing to model it..
you will be better off using a " Curtain Wall " for that design..
Easy to show
1. Varying heights
2. Gate
3. Gate Design ( Use Door Panel, customise it )
Curtain wall instead of railingsCurtain wall instead of railings
Corsten
Building Designer
