Railings, Multistorey Staircase, Revit to IFC - Problems
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
1710 Aufrufe, 4 Antworten
Hello everyone, I am having a pretty peculiar problem, which I can't solve. Or actually two problems.. 1. First problem: After exporting my building to IFC, the railing of this particular staircaise is shown above the staircase in the IFC model. However, it is not visible in REVIT, also via ID search. It just keeps showing when the upper top railing on the upper top staircase is drawn - individually or automaticly. I've attached the image. The staircaise is not a modelgroup/group. It is one consistent multistorey staircase. Ive tried to export only visible objects, via IFC settings. Ive tried to copy and replace, sketch individually, coply/delete and align the railing with no results, what so ever. However, if I completly delete the single railing, it wont show in the IFC model - But I need that one railing to appear correctly. VG settings have been checked to. Hope you can give a clue or an answer!
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Go to an elevation or section, select the multi-story stair and unpin each of its stair.  Then export to IFC and the railing will show correctly.
Nachricht 3 von 5
als Antwort auf: ToanDN
Hello ToanDN,
First of, thanks for the quick reply. I can't really unpin anything in the section. I don't have the option when picking lets say the staircaisepart in the "upper" level. I've attached a section view for you. Thanks in advance.
Nachricht 4 von 5
The pins are right in the middle of the stairs, not the ribbon. Click on them to unpin.
Nachricht 5 von 5
Thank your so much!
