Hey everyone,
I have a model of a retaining wall that has a railing on the top. I'm trying to recreate this railing but I can't align it by host. The element that I'm trying to use as a host is structural framing category. Is there any way to do it? Thanks!
EDIT: If I delete everything except railing, they are still standing. For example, If their host was the floor, If I delete the floor they will disappear too. I can't understand how they did it... Dynamo also doesn't help a lot.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
You can hide reference hosts in the view. We do it all the time. Don't delete. Hide instead.
Thank you! I tried this and its working. I just don't understand what they used as host, because it is missing... I deleted everything in the model and hidden elements except railing and they are still standing on the same place.
@barthbradley I wanted to send it by PM but you didn't answer. Thanks for help!
@ToanDN that was the missing part! Thank you!
If it was possible I would mark both answers as solution...
