Railings: Baluster Reference Error
9 ANTWORTEN 9
Nachricht 1 von 10
845 Aufrufe, 9 Antworten
My top reference for some of my balusters are below my bottom balusters. Not sure how to fix this. Can someone help?
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: Anonymous
Post a screenshot of your Edit Baluster Placement dialog box.
...or just post the file and we'll fix 'er up for you.
Nachricht 3 von 10
als Antwort auf: barthbradley
Does this help?
Nachricht 4 von 10
Not really. Where the handrail info?
Just post the file.
Nachricht 5 von 10
File of the stair is attached
Nachricht 6 von 10
Nachricht 7 von 10
That really helped thank you! But how do I align the balusters with the nearest stair and extend the bottom of the baluster so it's even with the bottom of a step it's mounted to?
Nachricht 8 von 10
Sorry, not following what you're asking.  Is this about Baluster Offset?
Nachricht 9 von 10
Just wandering back by and wondering how it is going.  Get it figured out yet?
Nachricht 10 von 10
Well the balusters are much better, but I still would like each baluster to look as if it was mounted to the side of a step, and not floating in between. I also want the length to be longer on the bottom of the baluster so that it looks flush with the bottom of the step. Perhaps that's the bottom offset, then just make each baluster longer?
