Railings Across Several Levels
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
phil_mcdevitt
332 Aufrufe, 5 Antworten
Hi All,
I have to place some rails on the stairs across several levels as in the below snapshot. To create the stairs I just used voids, not the stair tool. What is the best approach, do I need to create levels at the various landings?
Regards
Phil
5 ANTWORTEN 5
Nachricht 2 von 6
Ilic.Andrej
als Antwort auf: phil_mcdevitt
Why voids?Roboter (überrascht)
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 3 von 6
Avaris.
Hi Phil,
Best way to correct this, is to use multistorey stairs.
What you did is not very efficient. Try to use the Revit predefined families to draw stairs, railings and so on. That way you also take advantage of the BIM-idea. Right now you created 'dumb' objects, if you would have used the Revit-stairs you could also extract data from the stair objects.
Nachricht 4 von 6
You didn't use the Stair Tool? Why?  Seems like a pretty conventional Monolithic Stair.  You could pump those out all day long without even breaking a sweat by using the Stair Tool.  You could even incorporate the railing into the Stair Type.  Two birds with one stone modeling -- so to speak.  Smiley (zwinkernd)
...took roughly 15 seconds to do this one. I'm pooped.
Nachricht 5 von 6
phil_mcdevitt
als Antwort auf: Avaris.
Ok thanks, I will have a play around with it, might have to watch a few tutorials on U-Tube.
Regards
Phil
Nachricht 6 von 6
phil_mcdevitt
als Antwort auf: barthbradley
thanks for the advice.
