railing
railing
railing
hi. i want  to make glass railing but i think my settings are incorrect. i couldnt find it. railing's vertical elements are overflowing.thats problem 1. and if i change my settings and give number to vertical elements, then railing is not adjusted to the desired length.
ValentinaZusik
Here is the example of my settings:
Note that Dist. From previous Parameter should be a half of the Glass panel length.
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку 'УТВЕРДИТЬ РЕШЕНИЕ' | Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
VALENTINA ZUSIK
Facebook|LinkedIn
