Railing
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
492 Aufrufe, 4 Antworten
Railing
Hi All !
I am having slight issue with this railing.
First problem I have is to do with hosting it. Letter A is normal Floor, Letter B the little steps are made as a Floor type too and a Letter C the big steps are made as a Generic Model. I did offset bottom of the railing so it sinks in the floor/steps. Not sure if this is the way to do it.
Secondly letter D when turning the railing it behaves strangely , it shows in the plan view but in the 3d it doesn't exist and it host itself to the floor underneath.
Thirdly is there a way to spread each of the vertical elements of the railing separately so it matches the panel pattern behind ?
Thank you for all of your help.
Please see attached images :
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Why don't you build the big steps as a stair and host the railing to it?
Nachricht 3 von 5
als Antwort auf: ToanDN
This is exactly what I was getting previously. Please see the images below :
Nachricht 4 von 5
Change the stair run to stepped bottom instead of smooth bottom.
Nachricht 5 von 5
It worked ! Thank you !
