Nachricht 1 von 2
emergesecondary09
128 Aufrufe, 1 Antwort
Railing
I am having an issue in the visibilit of the railing in plan. In the below picture the railing goes inside the wall on both side of the column but they are join differently
Both side goes insde the wall but the left side is join such a way that it looks good in plan view. Please help me to get the desired look on both sides uniformely.
1 ANTWORT 1
Nachricht 2 von 2
azad.Nanva
als Antwort auf: emergesecondary09
i think the both side is wrong and not join, but one of them is under the floor so you can not see. you can not join the wall and Railing but you can use Break Pattern at for control better this work mostly but not always.
