Railing Tag and Linked Model
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
646 Aufrufe, 6 Antworten
I am having an issue with a linked revit file and railing tags.  I have Revit file that contains a linked model.  While I am in the main Revit file (where i have all my dims, annotations, tags, etc) I have tagged all the railings in the linked model.  I then save and close the file, but then when I re-open it all the railing tags have moved!  I try moving them back but the same thing happens again next time I open the file.  I have tagged many other objects (doors, windows, walls, etc) in the same file and no issues with those tags, just the railing tag.  The railing tag I created myself by editing the standard window tag that comes with Revit.  Any ideas on how to stop this from happening?
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Anonymous
Are the "moved" tags' still populated correctly, or are they orphaned?
Nachricht 3 von 7
als Antwort auf: barthbradley
Yes the moved tags still are populated with the correct railing number.
Nachricht 4 von 7
Well then, let's focus on the Tag itself. Maybe opening the Family with Audit checked, then saving and reloading it into the project will help.
Nachricht 5 von 7
Nachricht 6 von 7
This did the trick, problem solved!
Nachricht 7 von 7
Wow! Wonderful!
Thanks for the solution credit, @Anonymous.
Cheers!
