Hello, everyone.
I meet some problem to make rails.
I made with glass rail cover and glass together.
And I would like to see the section view as below picture.
However, when I cut my view, I can't see the separated material section view. Just looks like combine the material and show them without lines...
Like this.., Why can't I separate the materials..?
The reason why I made it Rail Structure is curve rail.
I've adjusted Detail Level and Visual Style. Detail Level is the same after trying all, and Visual Style is only visible in Wirefram.
I don't know what the problem is. Help me.
You mean you did something like this?
If so, maybe your issue is with View Scale or Line Weight with Thin Lines OFF.
Hi @jdhF2S5U
Thanks a lot for posting your question to the forums! Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
