railing problem
railing problem
FinearcLtd
railing problem
FinearcLtd
Anyone knows how to solve the flying around posts in the attached file containing a rail.
We need a solution urgently please!!!!
thanks!
rendermaster
select railing and press flip direction
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
FGPerraudin
hi @FinearcLtd,
Here is a version that works better.
You need to clearly organise your railing,
for example there I chose to spread pattern across the distance, and to not use posts.
I couls have chosen to use posts and to segment my trajectory according to the custom spreading I want, using posts.
Hope this helps,
Just have a comparative look between what I just sent and your original one.
François-Gabriel
Francois-Gabriel Perraudin
BIM management and coaching
