hi,
i am working on a revit architecture project and i am facing a problem in railing specially when we draft a railing on all the four side , the railing is ready but when i want to modify railing with the handrail parameter like select the type - pipe wall mount and then select the option for position- left/right/both of them so oce i do all these settings my railing appears correct but the position if i select any one of the three so i notice that in the railing three side are continuous flow of the position for left/right/both of them but the fourth side is not in continuous form in the railing so to make it accurate what should o do.
