Railing- problem with baluster
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
jjjoao2
1228 Aufrufe, 3 Antworten
Hi everyone,
Any suggestion to fix my baluster so that it can be aligned with the others?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: jjjoao2
Post the file.
I've got a couple of approaches I'd like to try using your stairs.
Nachricht 3 von 4
jjjoao2
als Antwort auf: barthbradley
Hi @barthbradley
Follow the link of the file....please help.
https://we.tl/t-QbQ0tr6cHP
Nachricht 4 von 4
Only thing I got for you is to make the the inside and outside rails two differently configured types (e.g. different baluster patterns).
You could Use Baluster Per Tread on Stairs (1 per Tread) to get them to align, but of course, that would significantly change the pattern by adding more balusters.
BTW: next time you want to post an RVT, just group the pertinent elements together in the Project and save the group out of the Project to a new, "skinny" Project -- and then post the "skinny" RVT directly here by Attaching it to a Reply Post.
