Having problem (not the first time!) with this rail. Please see the attached
Can someone assist me in this?
Gelöst! Gehe zur Lösung
Do you mean fixing the post poking through the stringer, or removing it altogether?
Hard to tell ho you get that post in there. Did you split the sketch line in two? How about sharing the model of the stair and railing?
check that bluster is attached to the right reference plan in the family it self and that you split the railing line where the slope angle changed
Hi @Anonymous
I just wanted to follow up on this post. Did the recommendations in this thread help resolve your issue?
Let us know if you are seeking more assistance from this community.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
