Railing Path Not Editable
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
hliS658H
194 Aufrufe, 2 Antworten
The railing I try to edit is not editable,  it is not in a group, the correct phase, why many properties and "edit path" are grayed out?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: hliS658H
Cut and paste aligned in place.
Nachricht 3 von 3
syman2000
Check and see if that object is pinned. Also check if someone own the workset so you cannot edit any of it.
