Does anyone know a way to control glass panel distribution in railing. See the attached picture and file to understand the problem I am facing. Not a new one, however, I hoped that version 2018 will bring a solution. Seems I was wrong.
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Panels (balusters) always have a fixed size, they don't adjust to the spacing or length of the railing.
If a glass railing is what you need, you can also make this with a curtain wall. Instead of using a top and bottom profile add mullions.
Hi @FinearcLtd
Please see the solution by @Alfredo_Medina the post HERE
Let us know if you were able to resolve the issue.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
