Trying out railing on topography from revit2018, but ain't working. Something doing wrong, can anyone help me? At moment it goes straight true the topo.
Gelöst! Gehe zur Lösung
Gelöst von JvanReij. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Works fine with simple Revit pick-point topography. I have not tried with imported topography yet.
@ToanDN is right, the railing tool should work. The only scenario where I notice it (logically) does not work is a topography that's split with the 'split surface' tool. Here only the selected host (topography) will be followed.
I've made (not specific for this post) a screencast of the railing hosted on topography tool and also how you can use it for other functions (a little trigger).
Best regards,
Josha van Reij
Arcadis NV
BIM manager
See u hosted topography. That what i forgot. Smart use new railing tool for family's, will use also. Thanks both toan and jreij.
