AnzeigenĀ Ā nurĀ  | Stattdessen suchen nachĀ
Meintest du:Ā
Railing not Display Properly in 2D & 3D View
6 ANTWORTEN 6
Nachricht 1 von 7
khurram43
559 Aufrufe, 6 Antworten
Dear Revit Experts,
I am using Revit for last ten years and this is the first time that I am facing problem while using Railing or any MEP System Command, If I draw Railing it shows not proper  display and one end seems thinner while next end seems bigger. Even same thing happening in Duct, Piping and Conduit. Attach are the images for your reference.
6 ANTWORTEN 6
Nachricht 2 von 7
ennujozlagam
als Antwort auf: khurram43
have you try to switch off your use hardware acceleration from options and see if helps. thanks
Nachricht 3 von 7
khurram43
als Antwort auf: ennujozlagam
Yes I did and even I try to make changes in display settings, hide hidden lines but still this shape existing. I forget to add that I am using Revit 2019-2020
Nachricht 4 von 7
Can you post some 2D images of your railing that shows the problem?  From your image it seems typical of perspective views, although I can't see any context to confirm that.
Nachricht 5 von 7
Do you have any CAD Links or Imports in the Project/View?  Turn them off and see if that resolves issue.
Nachricht 6 von 7
khurram43
als Antwort auf: barthbradley
Tried but not work out
Nachricht 7 von 7
khurram43
als Antwort auf: Anonymous
These are 2D Images
In Foren verƶffentlichen
