Dear friends,
Is there any way to put railing on stairs that have been made by Model in Place?
Pick New Host doesn’t work.
hello, pick your railing > select pick new host select stair. thanks
Good morning,
thank you for your reply, but Pick New Host doesn't work with my model in place stair.
my bad yes it will not work unless you create your customized railing family parameters or model your railing in-place in to your stair angle or post your stair so we can check. thanks
Draw an actual stair or a sloped floor to host the railing, then turn it off and leave the railing on the in-place stair.
hello, here is a quick railing, modify to suit your needs. thanks
Sorry, maybe I misunderstood from the beginning, my question now why she needs to model stair or slope floor and hide later on? If she can model the stair and add the railing? The reason-I don't know? It will affect the construction estimation? Just saying... thanks
Good morning,
At first side your solution is good, but I don't know the hide elements (in my project I have many of those stairs) what will course to the schedules.
On the other hand if I delete and not hide the cast in place stair the railing will be deleted too!
