Railing Help !!!!
4 ANTWORTEN 4
Nachricht 1 von 5
ritztran
1062 Aufrufe, 4 Antworten
Railing Help !!!!
I placed this railing and found out there are no pickets an turn. Can someone explain and teach me how to fix it? Thank you in advance.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: ritztran
I can think of a few things that could potentially cause this but my best guess is that you may have to adjust the baluster placement settings.
Can you post a screenshot of the settings dialog? Also what version of Revit are you using?
Nachricht 3 von 5
ritztran
als Antwort auf: Anonymous
Here are the screen shots of the railing
Nachricht 4 von 5
Sahay_R
Your baluster is set to a pattern - post+12 balusters+post. Revit does not see enough space to add the balusters in the highlighted area, so it takes the easy way out and omits them.
One solution - create a different railing style without a pattern for the highlighted area. Or try changing the value of Break Pattern At - to Each Segment End.
All else failing, please share a file for a more informed solution.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 5 von 5
Kimtaurus
Set Justify to something other than "Spread Pattern to Fit", next set Excess Length Fill to "Truncate Pattern".
Revit will repeat the baluster pattern until the end of the railing.
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
