Railing extensions not touching the ground
Sahay_R
Mentor Mentor
Sahay_R
The end posts on this railing are post+extension Baluster families. The extension is a Sweep. The Stair is attached.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Use Top Rail Extension and get rid of the one in the balusters.
Sahay_R
As always - perfect! Can't believe that I missed the Fillet thing! Thanks @ToanDN
Rina Sahay
drenL5229
Hi @ToanDN ,
I have a similar situation, but I have the railing extended after the stair finishes at the top. Since I have an angled railing at the top after it finishes (it doesn't continue straight with the railing at the stair) it is giving me a hard time to make e smooth transition. It does this strange gooseneck transition.
Please see below the attached picture.
Lachlan-JWP
Toggle the "End with Riser" property for that stair run.
drenL5229
@Lachlan-JWP ,
It didn't fixed it, the posts still go inside the floor at the top. I have mitigated it by offsetting (Landing Height Adjustment) the rail but I just don't like it that it is not correct.
@drenL5229 wrote:
Hi @ToanDN ,
Are you expecting it to be like this?  Maybe share your model here.
Perhaps start a new topic and share your model there because it appears to be a different issue altogether.
