Railing: Editing the path of the top rail, I can´t select a section of it
I´m edditingthe path of the top rail of a railing, I select just the top rail, the edit it´s path, the cursor can detect some sections of the path but the ones I need to edit aren´t being recognized
here´s the screencast:
https://autode.sk/37sCa9s
What are you trying to do?  Edit the Path?
..select Line on the Draw Panel and position the cursor at the end-point of the Top Rail Sketch. I see it highlighting as you pass over it in your GIF.
Yes, I´m editing the path
That´s the problem, the first ones are highlighted and can be selected, but the one i need is not highlighted neither recognized when I hover over it
at approximetly 20 s of the video the ones that are not being highlighted are shown
Looks like it's highlighting to me.
Just post your file. I'll take a look at it.
You can only modify the extension parts of the top rail path.
buckethead0226
ur on the right path, u can edit only by adding lines or editing joist to make smoother corner. 🙂
