Railing corner problem
4 ANTWORTEN 4
Nachricht 1 von 5
1035 Aufrufe, 4 Antworten
Something weird happens to this railing, if i choose a distance that is not modular to the glass then this happens...
Please !! Help
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Panels are fixed width. Create a Type that will fit that condition.
...or, divide the length by the number of Panels and create a Type that is equal to that length.
Nachricht 3 von 5
BDMackey
the other solution is to not make those panels balusters but to make them Railing supports, then to assign those supports to a Handrail (yes that is different than a railing), then assign that Handrail to a Railing, this way you can unpin the support and swap it out for one of a different size.
See this session on Revit Railings
https://www.autodesk.com/autodesk-university/class/Handrail-Hacks-2016
Nachricht 4 von 5
als Antwort auf: BDMackey
Handrail Hacks! One of my all-time favorites! You da man, @BDMackey.  Right up there with Marcello Sgambelluri.  :zwinkerndes_Gesicht:
Nachricht 5 von 5
BDMackey
@barthbradley thanks for that, comments like that make it worth while. I like sharing anything I can with the industry to make life a bit easier on all of us.
