I'm trying to create a railing on a staircase but the corners are not connecting.
But if I turn on the 'Top Rail' then the top rail is connecting the corners.
This results in 2 railings, both almost in the same place, one connecting the corners and the second not connecting the corners. However I want only one railing that connects the corners. I have tried already all the different settings at the joints and corners but nothing changes...
Is there maybe a way to have/show only the top rail? (Because this would solve my problem)
Gelöst! Gehe zur Lösung
Gelöst von martijn_pater. Gehe zur Lösung
To only have the top rail you can edit the railing type delete the other rail under rail structure, and ofcourse have top rail checked.
I didn't know/didn't think you could delete the 'main rail'.
Thanks for the solution!
FWIW, @Laura_POLO : I notice in your screenshot, that there is No Connector at Angled Joins. Is this by design?
